Author Topic: Reverse camera retrofit ?  (Read 11260 times)
Offline 182_blue
« on: 07 February 2015, 14:50 »
Anyone done this on the MK7, i did it on my MK5 but just wondered if there is a guide for the MK7 ?
Offline itavaltalainen
Re: Reverse camera retrofit ?
« Reply #1 on: 07 February 2015, 15:50 »
Can be done but the kit from Kufatec is pretty expensive (500£).
Then needs coding with VCDS.
Offline 182_blue
« Reply #2 on: 07 February 2015, 15:54 »
I know it can be done and can get the full kit for just over £200, just wondered if there i a guide knocking about.
« Reply #3 on: 07 February 2015, 18:45 »
to enable cam just code:
10 Einparkhilfe Byte 02, set Bit 4 to 1
5F Informationselektr. Byte 19, set Bit 4 to 1
Offline 182_blue
« Reply #4 on: 07 February 2015, 18:53 »
Thanks but was thinking more the wiring/ routing
Offline mcmaddy
« Reply #5 on: 07 February 2015, 19:18 »
Wiring is usually down the right hand side of the car when looking at the car from behind (drivers side in other words)
Offline 182_blue
« Reply #6 on: 07 February 2015, 19:25 »
Even on the MK7 ?, just thinking that it now connects up to the unit in the glovebox now and not the headunit..
Offline mcmaddy
« Reply #7 on: 07 February 2015, 19:28 »
You may need to look then but to be honest what's the difference between behind the head unit or in the glovebox, about three inches??
Offline 182_blue
« Reply #8 on: 07 February 2015, 19:30 »
In cabling routing terms its a lot more than 3 inches but i get your point.
« Reply #9 on: 07 February 2015, 23:27 »
Afaik VW route down the driver's side if fitted in factory but dealers have been known to run down the passenger side when retrofitting (on the continent at least).
