Author Topic: Turbo Actuator test  (Read 2582 times)
Offline Tezmax
Turbo Actuator test
« on: 14 January 2015, 18:18 »
How do i check my Turbo Actuator is working correctly without removing it?
I removed the vacuum hose and was led to believe the rod should move about
an inch but it didn't move anywhere :undecided:
Also do sticky vanes in a turbo occur more on diesels than petrols or about the same
Thanks.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline viperjsy
Re: Turbo Actuator test
« Reply #1 on: 15 January 2015, 00:38 »
try reving it to red line and let go while looking at the  Actuator to see if it moves but leave the hose on
Offline Tezmax
« Reply #2 on: 15 January 2015, 13:53 »
Yep got some movement once it reached 4.5k.
I take it my Actuator is working ok thanks.
Offline viperjsy
« Reply #3 on: 15 January 2015, 14:12 »
no problem m8
Offline ap_gt3
« Reply #4 on: 18 January 2015, 11:55 »
If you have a boost gauge you should be able to electrically unplug the n75 and see how worn your actuator spring is
Golf mk4 AUM... fmic, custom exhaust, 3" dp/decat, bbt actuator, s3 injectors, LCR fuel pump, sfs supersize tip, jetex filter, g60/vr6 clutch, badger 5 remap : 232.5 bhp / 242.3 lbft
Offline Tezmax
« Reply #5 on: 18 January 2015, 16:40 »
No gauge but tkx anyway.  :smiley:
