Author Topic: S3 seats - original fault is back  (Read 4406 times)
Offline barrym381
Re: S3 seats - think I got it sorted
« Reply #10 on: 16 January 2015, 22:47 »
Does the light illuminate for a second when the ignition is turned on?
I would guess it's a VAG only job as it's a safety feature...
the code reader my work has turned mine off after sorting my wiring not vag-com though  :smiley:
Offline G6otm
« Reply #11 on: 25 January 2015, 19:12 »
I have this problem!
I have s3 seats on mk4 frames and my airbag light is on.
I'm not sure what colour goes to what?
And do I need to soldier them together???
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #12 on: 25 January 2015, 19:43 »
The wires underneth are straight forward, Wazzer has posted the correct wires to which wires earlier in this topic.
So the fault code is back...It will go away for like a day if I clear it on VAGCOM but then re appears...
Says the resistance is too high somewhere!?  :undecided:
Offline brewey
Re: S3 seats - original fault is back
« Reply #13 on: 26 January 2015, 18:20 »
Sounds like a dodgy connection to me, as that's the message I got when the plug had worked itself loose. How did you connect the wires? Are you sure the wires were all in good condition?
2000 1.8T ARZ - OEM+
