Author Topic: Starter problems  (Read 3826 times)
Offline sparkplug
Re: Starter problems
« Reply #10 on: 25 January 2015, 09:37 »
if the starter was staying on all the time it would get very hot
pushing the clutch pedal & the noise goes away...are you sure its not the clutch release bearing or clutch making the noise ?
« Last Edit: 25 January 2015, 09:48 by sparkplug »
1986 GTI atlas grey
Offline Mcwill
« Reply #11 on: 25 January 2015, 11:08 »
Thanks foe the reply, I had a new clutch kit and g60 lightend and balanced flywheel fitted not that long ago.
The starter dose get hot, is there anyway of testing if its staying on?
Thanks
Offline sparkplug
« Reply #12 on: 25 January 2015, 17:32 »
i would look at the starter relay first , or the ignition switch ,as sounds like something is wired up wrong
1986 GTI atlas grey
Offline Mcwill
« Reply #13 on: 25 January 2015, 19:44 »
Ok will do thanks
