Author Topic: blue led door thingy  (Read 3166 times)
Offline HARDCOR3
Re: blue led door thingy
« Reply #10 on: 24 September 2005, 14:24 »
i'll source a pair of blue l,e,d's and build you a set, the surrounds are only about 30p each, i mostly built em for mk3's so don't have any surrounds in for Mk4, but any more orders, pm me, and if i get enough interest, i'll get a sh!t load and build any1 a set, i charge a tenner a pair, not per side as on flee-bay.. :wink:
Offline kniterider
  • had most, sold most and often buy more!
« Reply #11 on: 24 September 2005, 14:30 »
sounds good to me bud, let me know when yas have a pair and ill nip over and get em :smiley: i take it to get the one on the passenger door to work ill have to run wires from the drivers side door??
 :smiley:
Offline Phil_M
« Reply #12 on: 25 September 2005, 10:43 »
Apparently there is some wires in the passenger side door that can be picked up, Its just a case of findind out which ones.
 I found out this after i ran mine from the drivers side. :rolleyes:
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
Offline kniterider
« Reply #13 on: 25 September 2005, 10:48 »
handy to know!!!!! ill see if i can suss it out!!
 :cool:
Offline Phil_M
« Reply #14 on: 25 September 2005, 10:51 »
Here you go, Don't quote me on it as i haven't tried it.
The positive connection (green with a lilac stripe) has to go into pin 26 on the passenger side electric window connector, the earth wire (brown with a blue stripe) has to go to ground, before connecting the led a simple way to test this is to put a wire into pin 26 and connect a multimeter to it , when you arm the alarm there should be a constant or flashing 12v supply when armed!!
Offline HARDCOR3
« Reply #15 on: 25 September 2005, 10:58 »
i jumped both mine, off me dash alarm l,e,d, now i get all 3 flashing at the same time, looks well trick and belled to the max.... :laugh: :laugh:
