Author Topic: Did the 312mm brake upgrade today, now loads of brake pedal travel.  (Read 3882 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
warped discs are my bet...
Offline MoMartin
Yeah, that's my bet too. It seems to get better every day I  drive it though, so I'm still not 100 percent sure
Offline shaft69
Have you bled it from master cyl?? My pedal was sh!t when changed from Ap calliper so to R32 334mm bled it at master cyl then at calipers.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline MoMartin
It's a strange one haha, my car seemed to fix itself. What I thought was a warped disc seemed to smooth out over a week or two and with that smoothing out,  the brake pedal seemed to come back. So God knows what the problem was.
Now that it's mostly fixed I think that bleeding the system definitely couldn't do it any harm, as there is still a bit of travel / sponginess, but for now I can live with it and am quite happy with the upgrade.
Cheers for all the help
Offline gm8
im my experience of mk4 bleeding its a bloody nightmare. If you dont need to do it I wouldnt bother
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
It's easy enough to just run some new fluid through, it's when you change things it starts being a problem...
Offline MoMartin
When it comes to it I think I'll just pay for someone to do it because I've never bled brakes before and I'd rather not get it wrong
