Author Topic: Bend lighting error  (Read 38831 times)
Offline fredgroves
Re: Bend lighting error
« Reply #30 on: 09 November 2016, 16:29 »
No, definitely not.
Mine had one bulb done and the other blew a couple of weeks later.
Definitely can be fixed one at a time.
The problem I had with the dealer was that they didn't know what the error was or how to make the lights come on to test them!!!
(they know now....)
Offline Finglonga
« Reply #31 on: 10 November 2016, 13:01 »
turns out you cant change one bulb at a time...both have to be changed at the same time or it errors. 2 days without my car cos of something simple like that!
Has anyone heard of the system needing 2 new bulbs for it to clear? from a technical stand point i dont see how it could know the difference
on the plus side I got both bulbs for free and a kit kat for my trouble haha
I changed one bulb once when I dropped the new brighter one and it smashed. :angry: Had no problems for the time it took me to order a new one and for it to come.  I run LED's now and even running one LED and one Halogen when I was testing them didn't throw any errors.
Dealers don't seem to be able to diagnose problems physically now as everything is plugged in to get the error codes.
Offline JohnH
« Reply #32 on: 12 November 2016, 07:39 »
must be the time of year.  handy that this thread popped up as mine displayed the error yesterday
as others have commented, a slightly more descriptive error (and one that sounds les ££ to fix) would be better
new bulbs this morning then.
does anyone know what wattage the bulbs should be - i know it's in the manual, but it's raining  :smiley:
Offline dereks
« Reply #33 on: 13 November 2016, 11:05 »
Update on mine..Replaced both the bulbs and all ok now you could see inside the bulbs both has blown.
Offline Finglonga
« Reply #34 on: 13 November 2016, 13:03 »
H7, standard is 55w.
Offline monkeyhanger
« Reply #35 on: 20 November 2016, 09:20 »
Mine came on again on Friday night. Really must go and buy a new bulb. I think it's about the fifth time in 2 and a half years
They might last longer if they're replaced in pairs so the filaments of both are in the same state of wear/burn/resistance.
Offline boydeee
« Reply #36 on: 20 November 2016, 09:24 »
What type of H7 lamp are you using? I've had both mine go within the past few months. I've had the car for 2 and a half years also. I replaced with generic GE lamps as I think any of the uprated lamps have a much shorter life expectancy
Offline TonyJ
« Reply #37 on: 22 November 2016, 08:45 »
Both mine went in the space of a couple of months - car was about 2 years old.
Both replaced at local VW dealer
Current - Golf GTD Mk8
Previous - T-Roc R
Previous - Golf GTD Mk 7.5
Offline Snooze
« Reply #38 on: 22 November 2016, 20:35 »
My corner turning fogs have stopped working  :sad:
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
« Reply #39 on: 22 November 2016, 20:43 »
Osram nightbreaker plus H7s are under a tenner a pair at eurocarparts right now due to Black Friday deals.
