Author Topic: 3k issue??  (Read 4093 times)
Offline ritmo
Re: 3k issue??
« Reply #10 on: 24 December 2014, 00:52 »
no worse!
In fact trying not to use it as I don't want to get stranded anywhere!!
not had time to look at it.
glad you found your problem brighouse-gti.
Offline Mr Blue
Re: 3k issue??
« Reply #11 on: 25 December 2014, 22:22 »
no worse!
Think you need to source the leak first. The ecu is most likely fine. Digi ecu's either work or they don't.
Leak fix, dry out fuse box, replace water damaged relays.
 :smiley:
