Author Topic: Noticeable differences?  (Read 36410 times)
Offline yabot
Re: Noticeable differences?
« Reply #60 on: 02 December 2014, 09:50 »
Quote
Quote
Did you get your lights aligned after you fitted them?
Hmm no, havent had time yet, that essential is it?
Yeah dude, otherwise they'll be shining too high and blinding oncoming traffic! These Projectors are designed to cast a beam towards the left of the road so you'll illuminate signs and stuff, rather than right and into oncoming traffic. Theres white adjuster screws - use a torx screw to adjust em. Theres one for horizontal and one for vertical.
If you google it you'll find the standards - or do what I did and take em to a friendly MOT place and have em do it for you for free
Ah thanks pal, will mention it today when im at the Vagtech place see if they can do anything about it.
2011 3dr Mk6 GTI in CSG - Manual - RNS510/Bluetooth - Winter Pack - Optical Parking Assist - 18'' BBS SR Satin Grey - Few other bits' n bobs
Offline yabot
« Reply #61 on: 02 December 2014, 17:01 »
Hi again everyone,
Took my car to a vag specialist today. He got my Xenons working like OEM (i think). When the switch is on auto mode the DRL's are on at a high brightness during the day, when the light sensor detects night time, the xenons come on and the drl's dim down to what looks like 50% brightness.
HOWEVER, when the switch is on auto mode (which i leave it on), now that the xenons are fixed, it shows a bulb out error on the rear fog light with the fog light on. I'm taking it back Thursday but he said any help he can get (and me) would be much appreciated.
Any ideas?
Thanks again everyone  :kiss:
Offline yabot
« Reply #62 on: 02 December 2014, 20:19 »
Heres what im talking about. This is when the cars running and the switch is on auto mode.
Much appreciated.
Offline Booth11
« Reply #63 on: 02 December 2014, 21:20 »
So you mean when lights are switched to auto (and are actually on)! the fog light is always on?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline mike.
« Reply #64 on: 02 December 2014, 21:23 »
Just had a spin around since it's dark... i got a few flashes from people, 3 on a 10 minute drive... i know xenons are pretty bright since i sometimes think oncoming cars have their high beams on. but do you think mine might be pointing upwards abit more than they should?
Thanks guys
Did you fit the AFS unit and the autoleveller.
If you didn't then everytime you go over a bump or accelerate it will look like you are on full beam which would explain why you are getting flashed.
The fog light bulb out problem is usually a BYTE 18 mis coding problem.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline yabot
« Reply #65 on: 02 December 2014, 21:48 »
Yeah pretty much :(.
And no, there is no AFS unit or auto leveller, lights havent been aligned yet for the beam test so he's doing that thursday.
I remember him mentioning byte 18 and code 15 or something, but didnt work, we scoured through the forums for abit.
Offline golfhappy
« Reply #66 on: 02 December 2014, 22:42 »
Good luck with the error bulb...if you can post the long code for thr CECM byte 18 should be 04 me thinks.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline JayGTD
« Reply #67 on: 03 December 2014, 08:33 »
Morning dude. Byte 18 - 04 (GTI rest of the world) is what you want. I suspect what he did was he set the car to USA, and over there the fogs and reverse lights are swapped over.
Deep black pearl GTD | 18" Charleston wheels | Kenwood DNX520VBT | VWR Springs | GTI backbox and diffuser | Red grill stripes | Bi-xenon LED Projector's with 6000K HID's | Full interior LED conversion | LED Number plate lights | Heko wind deflectors | JDM Broadway Rearview mirror | GTD Seat inserts | Stage 1+ remap | Vagcom gauge sweep | Vagcom large digital speedo | Vagcom teardrop wipers | WIFI OB2 connector w/ Dashcommands |
Offline dubber36
« Reply #68 on: 03 December 2014, 09:34 »
That wouldn't put the fog or reversing light on all the time tho'. Until it's sorted, I'd pull the fog light bulb out to prevent annoying everyone behind you.
The DRLs should be at full brightness with the light switch in the OFF position as well as AUTO too.
Offline mustard
  • Mk7 R
« Reply #69 on: 03 December 2014, 14:07 »
I obtained these codes from VW Vortex and it seems to have worked for a few people:
MJ2009 with BCM (03xx software)
Encoding   VCDS Byte 18 = 04
Lights go out at the tailgate opens                         NO
Error message MFA   Rear fog lamp with Resistance: No
Problem with front parking light (weak light)                 NO
LED tailgate light up more when braking                 YES
MJ2010 with BCM from KW22/2009 (Software 0537, 0541)
Encoding                               Halogen VCDS Byte 18 = 15                                 Xenon VCDS Byte 18 = 43
Lights go out at the tailgate opens           NO                                                      Update on 0575 / 6 *
Error message MFA                                   NO                                                      Update on 0575 / 6 *
Problem with front parking light (weak light)   NO   Update on 0575 / 6 *
LED tailgate light up more when braking   NO   Update on 0575 / 6 *
With MJ2010 / BCM 2011 from KW45/2009 (0573 & 0575 Software / 0576)
Lights go out at the tailgate opens          YES                                                             YES
Error message MFA                                   NO                                                              NO
Problem with front parking light (weak light)   NO                                                              NO
LED tailgate light up more when braking   NO                                                              NO
