Author Topic: Clutch slipping, advice needed  (Read 4335 times)
Offline Dizzy_PD
Re: Clutch slipping, advice needed
« Reply #10 on: 07 November 2014, 18:08 »
ARL pd150 with 6 speed 02M gearbox. (240mm clutch kit)
I want something that will future proof, the Sachs sre kit is ideally rated to 360lbft.
I would like to stick with the DMF and don't wish to have a paddle clutch.
My options were the Sachs sre or the helix setup from awesome gti, but the outlay on both is immense.
I'm taking my time with this decision because my clutch is still manageable how it is at the moment.
Never heard of Borg & Beck as a manufacturer before, reputable?
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 07 November 2014, 19:44 »
I can say Borg & Beck have being around making clutches over 100 years and are still a major o.e supplier, I believe the only reason there not known like sachs or LUK is they are not part of huge multi national companies (Sachs is ZF and LUK is Schaeffer).
They do offer a full range of clutches with proper guarantee's and usually that bit less ££
Offline Bellend
« Reply #12 on: 07 November 2014, 20:02 »
Quote us for a PD130 6 speed if you like mate CU02 XBE.
Just about to get a SACHS DMF and clutch probably next week.
Where all my moneys went.
  • Back in a Mk3...
« Reply #13 on: 07 November 2014, 20:42 »
Borg & Beck is £138 (for a cover, plate and Slave Cyl 3 part kit) and I can do a sachs flywheel for £198.
Offline Dizzy_PD
« Reply #14 on: 08 November 2014, 01:41 »
Good price that, what sort of rating do they have? The Sachs OEM is said to just about hold 300lbft.
Do they do any uprated options?
  • Back in a Mk3...
« Reply #15 on: 08 November 2014, 09:01 »
Borg & Beck is said to be good to about 270lb/ft (standard are said to be 250lb/ft). They don't do any uprated options (I guess as it's a very difficult market to be in, what may work for some doesn't for other's)
Offline Bellend
« Reply #16 on: 08 November 2014, 09:02 »
Sweet. What's the lead time?
Would you recommend B&B over Sachs?
  • Back in a Mk3...
« Reply #17 on: 08 November 2014, 11:38 »
I certainly would recommend b&b over Sachs, both made to the same quality standards and both major o.e suppliers. Lead time is delivered to you within 2-3 days
