Author Topic: Touch screen issues when cold  (Read 23763 times)
Offline fredgroves
Re: Touch screen issues when cold
« Reply #20 on: 17 February 2016, 22:56 »
The "mode" button is there without DCC isn't it? That's how you select the different DCC setups anyway.
I've no idea where the parking function is, but after I wrote that earlier I noticed I do have two buttons right of the gearstick without anything on them.
I'm thinking about applying some stickers to them just to avoid the shame.
Was thinking maybe one for front machine guns and another for oil slick dispenser.
Offline Websta24
« Reply #21 on: 18 February 2016, 13:01 »
Car was in yesterday....went to pick it up and apparently the software update is ON BACK ORDER?????
How the friggin hell can a software update be on back order? Did they run out of links to copy to a SD Card?!?!?!?!? i was gob smacked
Offline Gorocco
« Reply #22 on: 18 March 2016, 15:52 »
Had my GTi a week now and have noticed the Discover Nav has a mind of it's own.
Appears fine in daylight but at night time I get the same problems as mentioned previously.
You'll press a station and it'll scroll instead. The Nav map appears to become inverted and the pointer will go off the page.
I really don't need this hassle  :sad:
PP, tints, Chassis Control.
Offline C2K
  • Northern Monkey
« Reply #23 on: 25 March 2016, 21:42 »
There's a tech bulletin out about this.  I have non navigation hu and had the freezing issue. The bulletin refers to a fault with the connector block,  calls up a replacement part which I'm waiting for a stealers phone call to have fitted.
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
Offline C2K
  • Northern Monkey
« Reply #24 on: 02 September 2016, 18:29 »
Fixed under warranty this week, tech bulletin describes a replacement plug for the head unit due to loose pins, and there's also a software update listed against a large number of vehicles to specifically combat freezing screens.
Mine is non navigation of course.
