Author Topic: What a mess this is!  (Read 3991 times)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: What a mess this is!
« Reply #10 on: 27 October 2014, 12:16 »
I'm confused :undecided:
The first image looks like your cut up one is smaller then the last picture it looks bigger?! The last picture looks like a polo bumper!?
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline MoMartin
« Reply #11 on: 27 October 2014, 12:27 »
it's to do with the camera angle, i took a picture from both sides try and highlight it, it just doesn't seem to show it very well
Offline SI74
« Reply #12 on: 27 October 2014, 13:33 »
Post up the part numbers of the two.
Offline matty james
« Reply #13 on: 27 October 2014, 20:28 »
in one of your pics they look the same size , are you shaw putting it on right - by sliding it onto the bracket things which are directly below the wings before you start bolting it on ???
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline matty james
« Reply #14 on: 27 October 2014, 20:50 »
your not trying to put your new bumber on with your intercooler still in the same place are you  :whistle:
Offline MoMartin
« Reply #15 on: 27 October 2014, 22:34 »
The part number is 1J0 807 217c, which is a match / should fit all mk4's
And i moved the intercooler back as far as i could, though i did leave the piping attached. So that might of affected it a bit. I think i'll remove everything this wednesday and try fitting it whilst the intercooler isn't attached at all.
Also yes, I have been installing it correctly, slide it on to the wings first then bolt on, but it wouldn't even slide on to them which has got me this confused  :undecided:
Offline mcgee9t2
« Reply #16 on: 28 October 2014, 06:39 »
My guess is pipe work down the o/a of the car
Offline brianpologti
« Reply #17 on: 28 October 2014, 09:48 »
As said no difference except rub strips, must be pipe work , unless it is off a 3.5 cab ?
Offline MoMartin
« Reply #18 on: 28 October 2014, 11:21 »
Well it was off an 02 plate tdi, so I don't think it was a cab, and yeah, give me a day or two and I'll remove everything that's In the way, and attempt to fit it again
« Reply #19 on: 28 October 2014, 13:10 »
As I have fitted standard bumpers to gti's a couple of times , only problem was the fm ic, Your not trying to fit the mounts twice are u ?Lol the slam panel straight ? I bet the fmic is hanging too low ,
