Author Topic: Darkside 1.8T front mount  (Read 6501 times)
Offline shaft69
Re: Darkside 1.8T front mount
« Reply #10 on: 02 November 2014, 15:39 »
my £75 welly cooler with 2.5" pipework around £200 all in Fitted yesterday.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 02 November 2014, 18:09 »
not gonna happen behind a standard bumper though lol
Offline shaft69
« Reply #12 on: 02 November 2014, 22:47 »
Wasn't this way in end had to turn it upside down, would poss fit behind standard bumper that way.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline rio_gti
« Reply #13 on: 03 November 2014, 08:12 »
looks good... you got air con?
Offline Dalo Harkin
« Reply #14 on: 03 November 2014, 12:21 »
Your thinking 'how the hell you get the vents in the R32 bumper without chopping them'
Offline shaft69
« Reply #15 on: 03 November 2014, 19:20 »
Yes have air con cos I turned cooler upside down cooler went nowhere near vents wouldn't fit way in 1st pic.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Scott D
« Reply #16 on: 03 November 2014, 19:32 »
looks a beast that FMIC and a tidy fit behind R32 front
where did you get the pipework done for N75 & DV take off?
Going down Wellycooler route early next year once xmas is out of the way
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline shaft69
« Reply #17 on: 03 November 2014, 19:37 »
Using 45 degree 63 alloy pipe mate fabricated 25 and 8mm pipes for £20 for dv and n75, removing n75 when new engine goings in later on with gt2871r fitting either aem or turbosmart ebc.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline rio_gti
« Reply #18 on: 04 November 2014, 14:06 »
lol yes I am!!
got a pic of that?
Offline shaft69
« Reply #19 on: 05 November 2014, 06:55 »
No but I'll put one up weekend take bumper off again.
184 Wallgate, Wigan
WN3 4AL
07966492823.
