Author Topic: Gt 140 tdi - annoying rattle  (Read 37037 times)
Offline JC
  • Back in the North.
« on: 17 October 2014, 20:09 »
So, 12oo miles in and i am now getting a tad annoyed by a rattle that appears to be coming from the bulkhead area on the passenger side.
only happens on ideal or intial take up of load, blip the throttle and it goes .
any suggestions - its dark when i get home so tomorrow is investigation day  :angry:
Offline S666LER
Re: Gt 140 tdi - annoying rattle
« Reply #1 on: 19 October 2014, 16:50 »
Mine has a rattle and I think its coming from the trim insert above the glovebox. Once I put pressure on it the noise stops. Maybe have a look there.
Offline Booth11
« Reply #2 on: 19 October 2014, 17:19 »
For ages, I had a similar rattle/buzzing from around the A pillar/glove box/passenger door area, drove me nuts.  It was most apparent at around 1500 rpm, so initially thought it might be the wastegate rattle.  Manipulation and gentle pressure (pushing in/out) applied to the long piece of door trim (down side of glove box) remedied it, eventually.
The sunglasses storage in the roof can also result in a buzzing noise that sounds like it's coming from round there so maybe check that.  I also had creaky door seals which caused rattling but Krytox sorted them.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline JC
« Reply #3 on: 19 October 2014, 17:23 »
oh this is a full on mechanical rattle, which u can kee rattling by correct holdin go revs,- as soon as u increase them or take up load it goes  :huh:
Offline Booth11
« Reply #4 on: 19 October 2014, 17:33 »
Wastegate rattle??  Easily fixed with a small clip.  What revs do you hear it at?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline JC
« Reply #5 on: 19 October 2014, 19:28 »
idle, or just off idle when taking up load on the clutch,  :huh:
Offline Rhyso
« Reply #6 on: 19 October 2014, 19:41 »
Release bearing??
Offline JC
« Reply #7 on: 19 October 2014, 19:43 »
Release bearing??
nah, same clutch in or out on idle .  :wink:
asked my old man to have a listen - what rattle  :lipsrsealed: :rolleyes:
Offline JC
« Reply #8 on: 12 March 2015, 11:58 »
Well its taken then 2 days, but VW have now found the rattle  :cool:
just going to take them 2 hours to rebuild the car and then i gotta go test drive it with the workshop manager and hand back this horrible polo  :sick: :sick: :sick: :sick:
Offline Sunny1Golf
« Reply #9 on: 08 July 2016, 22:50 »
MK6 GOLF GT 2010 growl noise VID!
https://youtu.be/NXizWDuHeBs
Anybody help me with this? Noise which comes when I start to drive. can't be the turbo as it only happens when moving up off and stops after gear 3. Like a proper diesel growl! No performance been affected but I'm sure it doesn't sound healthy? It only started happening now last 50/60 miles
Was yours similar to this noise mate?
