Golf mk4
Wazzzer
light alignment
Topic: light alignment (Read 3795 times)
matty james
Here all the time
Re: light alignment
Reply #10 on:
16 October 2014, 16:22 »
if no joy with my above post,take lights out and plug passengers in drivers side ,if still dim ,theres faulty or loose wiring in the light somewhere.
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Mark b
Re: light alignment
Reply #11 on:
16 October 2014, 17:46 »
just switched bulbs still the same
Standard gti 2.0 115bhp 2000 w reg
Mark b
Re: light alignment
Reply #12 on:
16 October 2014, 20:06 »
pic from tonight dont seem as bright at night but def still brighter
matty james
Here all the time
Re: light alignment
Reply #13 on:
16 October 2014, 22:51 »
have you wiggled the wires inside the light ,to see if it gets brighter/dimmer ? possible loose or faulty connection -also if i remember correctly the halo part of the light works by relflectin the light beam around the halo shaped glass tube by use of little chromed/polished plates- are they there like in the correctly working drivers side light?
matty james
Here all the time
Re: light alignment
Reply #14 on:
16 October 2014, 23:08 »
is the plug in back of the light plugged in tightly ? no broken or corroded pins in the plug ?
Mark b
Re: light alignment
Reply #15 on:
16 October 2014, 23:18 »
after close inspection I noticed the projector casing around the brightest light has a small gap around it wondering if that has affected the angle of the light as the other side is fine
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: light alignment
Reply #16 on:
17 October 2014, 00:04 »
yeah, one bulb probably has broken and refused filament.
Mark b
Re: light alignment
Reply #17 on:
17 October 2014, 07:07 »
if anyone here is in west london feel free to lend a hand lol ill have a proper look aftrr work today
Mark b
Re: light alignment
Reply #18 on:
17 October 2014, 21:15 »
did some adjustments tightened the projector lense and took this tonight
Scott-R
GoT BoosT!
Re: light alignment
Reply #19 on:
18 October 2014, 17:45 »
This may be nothing to do with the issue but the driver side should always be facing down more and not as bright as the passenger light, so you don't blind on coming vehicles... Correct?
Golf GTI ... What else would you have?
Golf mk4
Wazzzer
light alignment
