Author Topic: what lambda sensor do i need?  (Read 3999 times)
Offline itavaltalainen
Re: what lambda sensor do i need?
« Reply #10 on: 17 October 2014, 00:20 »
Brad did give you the part no of the bosch equivalent of the VW part number I gave you.
It's probably one of the cases where it originally had a shorter cable fitted but the spare is longer (to allocate for a number of cars where cable length is only difference).
I once fitted a know sensor from an A4 to my 2.0 2E engine.... same knock sensor only difference was cable was 20cm longer; and it was a third of the price of the one originally fitted to the 2E (knew it fitted ok because the unit fitted on 2E was used on other manufacturers engines where the Bosch p/n for the A4 sensor was listed as a poss replacement).
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 17 October 2014, 09:52 »
both the 690 and 910 cable length are available to me next day (direct from Bosch) and can be posted 1st class, so 2-3 days to you
Offline TEST100
« Reply #12 on: 18 October 2014, 20:42 »
Ok kool.cheers for all your advice guys.im fitting my new ngk ntk 660mm lambda sensor tomoz.it cost 65 from motor parts direct same day.ordered in morning collected in evening
i hope it solves the power issues.fingers crossed.
by the way,i had to drop cat from manifold so i could twist it to get lambda out.not an easy job.too be honest every job on an old car where everythings rusted tight.aint easy lol
Offline TEST100
« Reply #13 on: 19 October 2014, 12:52 »
Yep problem sorted.over the moon  :smiley: :smiley: :smiley:
