Author Topic: Bad PCV valve with video?  (Read 6664 times)
Offline kxtian
Re: Bad PCV valve with video?
« Reply #10 on: 04 November 2014, 17:47 »
ALSO!! If your careful enough, you can pop the lid off the existing pcv (careful not to break tabs) and check the rubber diaphragm inside. If it's ripped there's your answer.
Offline Egbutt Wash
« Reply #11 on: 15 November 2014, 00:12 »
Usual VW cost cutting rubbish
Currently digging a bunker.
Offline goodsum
« Reply #12 on: 19 January 2015, 14:19 »
I finally got round to replacing my PCV over christmas. I reset the engine management light and am now some 700 miles or so later and it hasn't returned. It used to come back after about 200 miles. I haven't had my usual rev issues on idle either, so everything points to it being fixed!!
Also the noise that VW told me was my clutch release bearing has gone too. I'm well chuffed with that!! A £30 part which took 5 minutes to fit has solved all the problems on my car  :grin: Obviously replacing just the clutch would have been more than 10 times the cost which VW were encouraging me to do!!!
