Author Topic: 17" wheels causing a wibbble ah  (Read 3114 times)
Offline Len
Re: 17" wheels causing a wibbble ah
« Reply #10 on: 12 September 2005, 20:54 »
No need to shout Lisa! :grin:
Also you may find that you tramline. This is where your tyres follow contours on the road, like white lines or where trenches have been cut in the tarmac etc.
Mind you first thing to check is that the wheels are properly fitted! Check that they are tight to the hub and that the wheel nits are tight!!!
I know that sounds daft, but unless you are sure they are fitted correctly..........
www.sas.org.uk
www.the-ace.org.uk
Offline lisa30
« Reply #11 on: 13 September 2005, 09:06 »
Soz chick ill speak quiet now
So annoying when ya dont know whats up
I had me tracking checked on the wheels and there fine nuts are tight all is on good
Lad did say could be the gap between wheel n arch ie have my suspension lowered
as could be the cause of the wibble  :sad:
Gotta take it back to nit for pt 2 check over
[img]http://img.photobucket.com/albums/v714/lisa30/car.jpg
