Author Topic: Original exhaust  (Read 1454 times)
Offline antgel
Original exhaust
« on: 11 September 2005, 22:32 »
My exhaust back box has two pipes at the very rear.  Is this OE on a 1988 GTi?
Offline shaft69
Re: Original exhaust
« Reply #1 on: 11 September 2005, 22:56 »
YES
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Hatchet Harry
« Reply #2 on: 11 September 2005, 23:02 »
the box over the rear beam is very restrictive though u should loose that one..
Offline wellfan
« Reply #3 on: 12 September 2005, 21:22 »
'the box over the rear beam is very restrictive though u should loose that one'
How do we do that one?
Offline Dizzie
  • Make friends with your fast
« Reply #4 on: 13 September 2005, 08:39 »
there is no box over the rear beam? There's a box either side. It's all resrictive unless u have a custom free flow system made up.
Offline Gambit
« Reply #5 on: 13 September 2005, 13:25 »
and its not restrictive either if its a OE VAG item. the OE VAG items are just as well flowed as any stainless steel system from down pipe back. post on ClubGTI ages ago with dyno's to prove it
