Author Topic: valve springs  (Read 3826 times)
roberto
Re: valve springs
« Reply #10 on: 25 August 2014, 14:24 »
soooo any of you fellas have an answer to my original question? :huh:
Offline Sgt_Lemon
  • 8v owners club
Re: valve springs
« Reply #11 on: 25 August 2014, 17:39 »
Surely if the valve length is the same and there are matching springs and collet washer it shouldnt matter really. I would put on the pb dual springs and collet washer if the collets are the same groove style for the different valves. I still don't see where the gains are to be had. Guide work wasn't cheap when I had it done. £5 a valve guide plus £5 for them to be honed plus vat. That's £50 to fit valves with a slightly thinner shaft.
roberto
Re: valve springs
« Reply #12 on: 25 August 2014, 18:59 »
but the thing is that the double springs wont work with the agg exhaust valves. the collets/caps and springs are all different. the agg inlets are longer than the pb ones so not sure I want to risk fitting them as they might bottom out the tappets after the seats in the head have been re-cut. which is why I want to retain the original inlet valves. £5 for each guide :shocked:. I have ordered a set of febi guides from gsf for £3.20 each.
Offline Sgt_Lemon
  • 8v owners club
Re: valve springs
« Reply #13 on: 26 August 2014, 14:59 »
I forgot the cost of the guides themselves. Where are you getting the guides fitted and honed at?
roberto
Re: valve springs
« Reply #14 on: 07 September 2014, 18:02 »
fitting the guides myself. not sure where im getting the clearances done yet.
