Author Topic: Low Coolant Warning Light  (Read 12866 times)
Offline AdmiralGant
« on: 12 August 2014, 21:42 »
Hi,
Had the low coolant warning light come on when I started up this morning, I got out and checked and noticed it was about an inch below the minimum level.
I then started the engine again and the light did not come back on. I then put a pint of water in tonight.
I cannot see any leaks from the radiator, I don't remember hitting anything and have had no steam etc.
Has anyone else had need to top up their water coolant reservoir? The car has done about 7k.
Thanks
Fleet
On Order - BMW 330d M Sport with M Sport Plus pack, voodoo lights, adaptive cruise, dampers - Battleship
Decommissioned 20/1/16 - GTD Mk 7 DSG 5dr Carbon Grey, ACC, Winter Pack, Class - Pocket Battleship (Flagship) - commissioned 21/1/14
Seat Ibiza FR TDI 130, Flame Red, Class - Frigate - commissioned 01/09/07
Suzuki Jimny 1.3 JLX+, quasar grey, Class - destroyer - commissioned 30/11/08
Suzuki Bandit 650, red, Class - covette - commissioned 01/09/05
Offline peterdoherty
Re: Low Coolant Warning Light
« Reply #1 on: 12 August 2014, 21:47 »
Yep same here - did it last week when hit around 9k (GTD) - used coolant from halfords rather than water though.
In for a service this Thursday so was going to query it or have it noted on file as thought it was strange.
MKVII GTD DSG Carbon Grey 5DR, Dynaudio, Keyless Entry, Rear View Camera, Colour MFD, Park Assist, Winter Pack, Climate Screen, Advanced Phone Kit, High Beam Assist
Offline ben62806
« Reply #2 on: 12 August 2014, 21:48 »
Hi,  I wouldn't worry unless it drops again,  it's quite common to top up the coolant in between services on these modern engines.  We find we have to top up 8 out of  10 cars on their first service.  If you've done 7000 miles you will soon have a service where volkswagen can check it over. Just keep an eye on it  :smiley:
Offline marnie
« Reply #3 on: 12 August 2014, 23:48 »
If you used tap water and not distilled water you will be causing engine damage. You should get it drained and filled with VW G13 coolant asap. Assuming this applies to a GTD as well as a GTI.
« Last Edit: 12 August 2014, 23:50 by marnie »
Mk7 GTI 5 Dr
Offline Gnasher
  • Formerly GnasherVXR
« Reply #4 on: 13 August 2014, 05:31 »
Coolant (of which there will still be plenty of in the cooling system) has a corrosion inhibitor - just for topping up, tap water will be fine.
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline corgi
« Reply #5 on: 13 August 2014, 08:35 »
Gnasher is spot on here... tap water is fine in relatively small quantities... had the same with mine the other morning, the level was a little below the minimum...
Why do "these modern engines" need a top-up between services? The coolant must be going somewhere... I'm not concerned but I would like to understand what is different about a modern engine because the only time I've had to top coolant up in the past is when it had leaked out because of a split hose or on one car a head gasket issue failure so it was going out of the exhaust...
Corgi
Offline MajorKhan
« Reply #6 on: 13 August 2014, 14:38 »
Ive had the same, I believe it is due with the type of engine (prefer water to filling up with oil like the bmw engines) also aircon may add to the water loss.
From a Pulsar GTIR, MK4 Golf 1.8t, BMW 1series, BMW 330, Merc C280, A3 TDi, A4 2.0t Quattro...on order Mk7 T/Red GTD nav/pan roof/dynoaudio and ABT headlight brow BW44!
Offline itavaltalainen
« Reply #7 on: 13 August 2014, 15:13 »
The mk7 engines don't need topping up in between services... they may need some on first service because when the car leaves factory it will always still have a little bit of air in the system (which is quite complex on the mk7), plus hoses expand a bit when they got hot a few times over the first few k miles. These things will cause the level to go down a bit, even though there's no leak.
All absolutely normal and been like this with pretty much all new cars in the last decades.
Offline joet
« Reply #8 on: 13 August 2014, 21:26 »
I had the same on my GTI. Asked them to look at it at the first service and they found a small leak in the water pump. Replaced under warranty and it's been fine since then
Offline skippy
« Reply #9 on: 13 August 2014, 22:14 »
Just to add to this thread, my Scirocco had a water leak a few years ago (turned out to be the water pump) and the dealer said tap water would be ok in small quantities. Distilled water is preferable though.
MK7.5 2020, Isaac Blue, standard spec
Gone but certainly not forgotten Candy White Scirocco 2.0 TSI
