Author Topic: SD CARD NOT READING!!!  (Read 11117 times)
Offline GeoBog
Re: SD CARD NOT READING!!!
« Reply #10 on: 07 August 2014, 21:48 »
In the manual it says SDHC up to 32 GB and SDXC up to 2 TB
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline marnie
« Reply #11 on: 07 August 2014, 22:34 »
Micro SD in SD adapter works fine in my CMS.
Mk7 GTI 5 Dr
Offline JohnH
« Reply #12 on: 08 August 2014, 20:33 »
My bets are on it will only allow up to 32GB's like the Audi's  :whistle:
i'm using a 128GB without issues
Offline Nav
« Reply #13 on: 10 August 2014, 16:33 »
Ah. Cheers for replies guys.
Has anyone else experienced this problem?
Vw Golf GTD MK7 Carbon Grey, heated seats, discover Navigation and Dynaudio
Ford Focus 1.6 zetec climate
Offline Adam
« Reply #14 on: 11 August 2014, 12:29 »
That will be a SDXC card..
Down Hill From Here.
Offline kevinm
« Reply #15 on: 11 August 2014, 16:22 »
As said above, cards over 32GB have to be SDXC. I'm using a 64GB SDXC without problems
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline JohnH
« Reply #16 on: 11 August 2014, 18:19 »
in case it helps, this is the card I use
http://www.amazon.co.uk/gp/product/B0090J5XLS/
Offline zumik83
« Reply #17 on: 14 April 2023, 08:04 »
I got you covered. I bought a SANDISK 400 GB (four hundred GigaBytes) microSDXC and I got it to finally work in my Golf 7. So, what you need to do is use EaseUS Partition Master or something similar, format the drive as FAT32, but what you ABSOLUTELY NEED TO DO is to make that partition a PRIMARY one. By default, in EaseUS Partition Master when you create a partition, you are presented with all these options, size, allocation size, drive letter, type but it is only when you click ADVANCED you can choose wheater the new partition will be a LOGICAL one or PRIMARY. Logical partition is the default option. I chose PRIMARY and the microSD was visible. That is the key, the SD partition NEED to be set as a PRIMARY partition. When I created a logical FAT32 partition, the car was unable to read the SD.
