Author Topic: changing sports cat for a decat  (Read 1447 times)
Offline Dalo Harkin
« on: 05 August 2014, 08:45 »
Would my map need amending or not? think my sports cat is on its way out, would I also see any power gains?
Offline Scott D
Re: changing sports cat for a decat
« Reply #1 on: 05 August 2014, 18:07 »
Probably willl need mapping to up the lambda limit avoiding fault codes and ECU light
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline shaft69
« Reply #2 on: 09 August 2014, 18:04 »
Can use 42dd after cat (monitoring sensor) lambda spacer keep light off only one I know that actually works.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
