Golf mk4
Wazzzer
vacuum lines
Topic: vacuum lines (Read 1739 times)
shaggywolfhound
Just got here
vacuum lines
02 August 2014, 11:16 »
I'm starting to bit by bit change my vac lines. I have 4mm silicon tubing 6m just in case so I've got some spare. I want to know is there a diagram/guide of where exactly all the lines are? Presume I can literally just replace or is there more to it? Oh yeah Golf GTI Mkiv 1.8 turbo AGU engine.
Ta in advance.
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: vacuum lines
02 August 2014, 14:51 »
You have 2 take off on your inlet mani, one goes to the fuel pressure regulator, the other to your DV
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
shaggywolfhound
Just got here
Re: vacuum lines
03 August 2014, 07:41 »
I've done those two pipes, bypassing the metal one, but it's the other ones I was looking for?
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: vacuum lines
03 August 2014, 11:04 »
There aren't any more on the AGU as far as I know, unless you T off for a boost gauge. You could replace the actuator pipe I spose but the standard one has a heat resistant sleeve on it
shaggywolfhound
Just got here
Re: vacuum lines
03 August 2014, 13:06 »
Well that explains that then. I thought I was going nuts.
Golf mk4
Wazzzer
vacuum lines
