Golf mk4
Wazzzer
1.8 t aum 2002 fault code
Topic: 1.8 t aum 2002 fault code (Read 1442 times)
shiloh
01 August 2014, 20:33 »
Hi folks,
I have this fault code 16795 which I believe is something to do with the secondary air system, could anyone tell me if this is something that will effect performance or is it one of these codes I can just ignore?
Dalo Harkin
Re: 1.8 t aum 2002 fault code
02 August 2014, 09:23 »
If it is definitely the SAI then you can forget it because all the SAI does is pretty heat the cat
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Golf mk4
Wazzzer
