Author Topic: wheel nuts  (Read 2113 times)
Offline Mark b
wheel nuts
« on: 31 July 2014, 16:50 »
hi all the garage I got my car fixed has lost my locking nut key so I need to replace 4 nuts does anyone know the actual size of the nuts id need ?
Standard gti 2.0 115bhp 2000 w reg
Offline mcgee9t2
Re: wheel nuts
« Reply #1 on: 31 July 2014, 17:51 »
problem no.1
they loose it they replace it imo. if they cant find the type of bolts needed then id be questioning taking a car to them...
especially seens all they have to do is ring paiges or who ever they use for parts, quote the reg and say they need wheel nuts... the parts distributor will give them the correct parts
as for what size they are:-
Outer Thread (mm)
m14 X 1,5
Spanner Size
17
Thread Length (mm)
24 (or 28 cant remember which)
go on eurocar parts or simelar they will give you all the info you need if you put your reg in
Offline Mark b
Re: wheel nuts
« Reply #2 on: 31 July 2014, 19:13 »
cheers for the info much appreciated
Re: wheel nuts
« Reply #3 on: 31 July 2014, 23:50 »
You will need a different taper if your alloys are aftermarket.
Offline Mark b
Re: wheel nuts
« Reply #4 on: 02 August 2014, 00:51 »
ive got rs4 18' reps I think multistud
Offline benmanc
Re: wheel nuts
« Reply #5 on: 02 August 2014, 08:38 »
f**king retards. How do you even lose one?
They should sort it out.
Idiots.
I literally have no useful input im just angry at reading this haha.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: wheel nuts
« Reply #6 on: 02 August 2014, 14:53 »
like Wayne said you will need tapered bolts for those wheels
