Author Topic: Fitting Forge Actuator?  (Read 7300 times)
Offline Chris.
Re: Fitting Forge Actuator?
« Reply #10 on: 01 August 2014, 21:20 »
Is that definitely a forge actuator?  Never seen them in that shape before.
Click For Build Thread
Offline Kruga
  • Silver - MK4 1.8T AGU 2000
« Reply #11 on: 01 August 2014, 22:43 »
Yes its a forge i bought it off oceanic-green of this site its called a FMACVAG03G got a yellow spring in it, i emailed the guys at forge and they said this:
Quote
you will likely find the original rod is ¼” UNF whereas ours is M6 which is much more standard.
As long as the rod still goes through the eyelet on the turbo it wont make any difference
I managed to get the rod in and watched a video on youtube that i think you made Chris haha
https://www.youtube.com/watch?v=NtJDy6Ipm9I&list=WL
« Last Edit: 01 August 2014, 23:04 by Kruga »
Offline Chris.
« Reply #12 on: 02 August 2014, 14:35 »
I certainly did ;)
Offline Kruga
« Reply #13 on: 02 August 2014, 15:27 »
Well thanks for doing that vid chris now the actuators all setup and the turbo just needs installing  :smiley:
