Author Topic: lowering springs  (Read 2197 times)
Offline Mark b
lowering springs
« on: 26 July 2014, 23:43 »
evening peeps at the mo my car is completely standard seen a set of 40mm lowering springs will I need to make any changes to lower the car and would these go on standard shocks?
Standard gti 2.0 115bhp 2000 w reg
Offline SI74
Re: lowering springs
« Reply #1 on: 27 July 2014, 17:45 »
Save up and get coilovers.  I ran 30mm springs for a while and didn't do any other mods but with coils it give you a better scale to go with whatever ride high you want.
The shocks will work but more than like be a different rate to the springs.
Offline andc1
« Reply #2 on: 03 August 2014, 00:15 »
Yep agreed def save u for collies, any lower than 40mm will require anti roll bar adjustment
« Reply #3 on: 03 August 2014, 21:28 »
They will be ok but replace the shocks with new at the same time.
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #4 on: 04 August 2014, 09:18 »
I got 40mm lowering springs on mine. The car holds really well but my god its hard as f**k :shocked:
Every little hole and bump feels like a speed bump and say good bye to the undertray of your engine if you do hit a bump!
Saving for coil overs now!
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline Mark b
« Reply #5 on: 04 August 2014, 11:46 »
so I don’t have to change anything what mm drop will be ok on my car my shocks ect are all standard
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 04 August 2014, 12:48 »
If using std shocks I would say no lower than 30mm (and even that will lower the life of the shockers quite a bit too), although I sell 4 shortened shocks and 4 lowering springs for £139 (40mm all round and should be fine with std anti roll bar)
I also advise to check the poundage of lowering springs or you can get super over stiff suspension (My kits are rated at 960kg front axle weight)
