Author Topic: Locking wheel nut stuck. SUCCESS !!  (Read 6464 times)
Offline gm8
Re: Locking wheel nut stuck.
« Reply #10 on: 27 July 2014, 11:39 »
as said a smaller socket , just be prepared to beat the sh!t out of it to get it on
Offline MPFIEND
« Reply #11 on: 27 July 2014, 16:55 »
Thanks Gm8, I had a look today but don't have a 19mm 12 point socket at home only a 6 point.
 I'm going to get a new set of locking wheel nuts tomorrow from the dealer, so then I can work on the stubborn one. After I find a suitable socket.
If any one has any different views on this I'd like to read them.
Best Regards
Keith.
« Last Edit: 27 July 2014, 16:58 by MPFIEND »
Offline mustard
  • Mk7 R
« Reply #12 on: 27 July 2014, 17:20 »
Could try this, I looked at it when I could get one of my McGard nuts off, but fortunately my local tyre place did it for free.
http://www.screwfix.com/p/laser-emergency-locking-wheel-nut-remover-set-4-pieces/94826
Offline MPFIEND
« Reply #13 on: 27 July 2014, 17:44 »
Thanks mustard, will these fit ? I have monza 2 shadows and the clearance looks very small between the nut and the wheel.
Has any body tried these?
Best Regards
Keith.
Offline andygo
« Reply #14 on: 28 July 2014, 22:41 »
A mate of mine owns a car dealers. Its been going in the family for just over 100 years. he really loosens off all the other bolts on the wheel and then gently drives it round the car park. The offending bolt loosens fairly quickly, and if you check it frequently, no damage is done.
He has done loads like this, he's a really careful guy, preps race cars for a hobby..
Offline C2K
  • Northern Monkey
« Reply #15 on: 28 July 2014, 23:20 »
That's the same trick I use for seized hub nuts like rovers lol. Get an almighty clunk when it shuttles the shaft against the nut.
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
Offline MPFIEND
« Reply #16 on: 29 July 2014, 08:52 »
Andy, C2K, thanks for the tips Gents I'll give it a try.
I have now tried the 19mm socket but this size seems far to small, I removed one of the other locking bolts and measured it, the outside diameter is 23.5mm and the bore of the wheel is around 30mm. So the 19mm socket will have to yield by almost 2mm to fit over the bolt and a larger socket may not fit into the recess in the wheel.
off to a dark room to have another think.....
Best Regards
Keith
Offline MPFIEND
Re: Locking wheel nut stuck. SUCCESS !!
« Reply #17 on: 30 July 2014, 10:17 »
Well after a lay down in a dark room, and really not wanting to go to a dealer or tyre fitter, I found a mate at work that owned a Snap on impact driver.
After loosening the other three locking wheel nuts first I went to work on the stubborn one. Forcing the gun and the key socket firmly against the nut then fired it up. After about 5 mins nothing was happening, so I tried agin then it finally went.(15 minutes later)
I am so relieved at this. Now I can clean the wheel and fit the new set of locking wheel nuts correctly.
Thanks Gents for all your input, this forum is definitely a fantastic resource, with very helpful members.
Best Regards
Keith.
Offline Mattyj
« Reply #18 on: 31 July 2014, 21:42 »
I'm kinda confused what you guys are on about my locking wheel nuts are round not hex shaped so couldn't bang a socket on and the nuts tight in the alloy wheel nut bore so you couldn't get anything over it
Offline madmanmart
« Reply #19 on: 31 July 2014, 22:22 »
Best Regards
Keith.
Great that your sorted.
Best idea is to buy a set of original bolts and ditch the lockers all together. It not the 1980s anymore so people don't go round stealing alloy wheels and CD players.  :grin:
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
