Author Topic: wobbly back end  (Read 4367 times)
Offline boneybradley
  • Back in a Mk3...
Re: wobbly back end
« Reply #10 on: 25 July 2014, 13:41 »
I will say rear axle mounts (when bad they give a feeling of rear steer as the axle moves around corner's)... I would also check condition of your rear shockers as they will fail really quick with worn bushes! (the mounts are simply rubber and rarely fail, although I always fit a set when changing shockers as they are cheap)
Mine are £23 a pair with new bolts http://oemandmore.co.uk/rear-axle-beam-mounting-kit-febi-pro-kit-351-p.asp
Offline chrisbeg34
Re: wobbly back end
« Reply #11 on: 25 July 2014, 17:55 »
ok just had the car up def shock problem, oil all over the place. this  might explain a few things  :smug: will change this and fingers crossed that will fix it all, mounts look good, no movement
Re: wobbly back end
« Reply #12 on: 25 July 2014, 23:33 »
For what the top shock mounts cost I would replace them.
Offline chrisbeg34
Re: wobbly back end
« Reply #13 on: 25 July 2014, 23:58 »
agree with you there, will replace at the same time :wink:
