Author Topic: Turbo Options 1.8T  (Read 9592 times)
Offline barrym381
Re: Turbo Options 1.8T
« Reply #20 on: 21 July 2014, 19:40 »
Also another question say i find leon cupra at the scrappy that does have k03s will i be able to take that off and put it onto mine or do i need to find a specific cupra for my agu golf?
probably a dumb question but oh well
just check the engine code an make sure its not a cupra r but there is plenty of aum golfs breaking in here surely 1 of them has a k03s for sale  :smiley:
Are AUM's and AGU's similar then? ill have a look around them then appreciated
the aum is fitted with the ko3s as standard so is the auq in golfs and some leon cupras  :smiley:
Offline Kruga
  • Silver - MK4 1.8T AGU 2000
« Reply #21 on: 21 July 2014, 19:45 »
Awesome man cheers! gonna have a look round see if anyones breaking them models :grin:
Offline james2
  • No scammers please.
« Reply #22 on: 21 July 2014, 20:24 »
« Last Edit: 21 July 2014, 20:27 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline shaft69
« Reply #23 on: 21 July 2014, 21:04 »
Turbo wise agu uses ko3 aum ko3s cyl heads different too.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Kruga
« Reply #24 on: 24 July 2014, 17:57 »
One last question what exactly am i looking for in a k03s like good or bad signs? and is there a part number for them as the local scrappy (car transplants) no longer allows people to walk around the yard and look at cars you got to sit in the waiting room while they find the part for you...
Offline MoMartin
« Reply #25 on: 25 July 2014, 15:36 »
things to look for -
- minimal shaft play (shouldn't hit the sides in any place - a bit of play is normal though)
- cracks anywhere is generally a bad sign (though some people argue that small cracks on the hot side doesnt effect boost / performance)
- cracks on the wastegate
- oil in the turbine
part no is either 5303 988 0052 or 5303 988 0026
Offline shaft69
« Reply #26 on: 25 July 2014, 19:04 »
Would you get k04??
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Kruga
« Reply #27 on: 25 July 2014, 19:19 »
Does this look ok i know its not much to go by but are the "8 Curved fins" a problem?
And wouldnt a k04 setup require me to change a few other parts tho?
Offline shaft69
« Reply #28 on: 25 July 2014, 19:42 »
Have k04, lines, injectors, map to for set up with emission deletes, immo defeat and manifold  for sale momth or so time. Only need maf housing and tip 280hp. Brum brum.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Kruga
« Reply #29 on: 25 July 2014, 19:45 »
Ye but how much would all that cost me compared to what a k03s will cost me? i know k04 means more power but ive still got to buy a decent fmic haha
