Author Topic: AGU engine into an AUM car??? (sorry if posted before have tried searching)  (Read 3600 times)
Offline 1.8t-ste
Non of the 1.8t come with forged internals from factory. All 1.8t should run a recirculating diverter valve unless mapped for atmospheric dump valve.
If you're going for big power it doesn't matter what engine you go for if you're going to change all the internals anyway but I would advise you to keep the AUM ecu, sensors and loom. So with that in mind I would suggest getting a bare block, any 1.8t block with internal water pump, build it up with your choice of internals, inspect and slap the AUM head on it and drop it back in. Done.
Quite a few have gone 2.1 stroker and recommend it for larger frame turbos, integrated engineering are a good vendor to buy from, badger5 are an official UK distributor for integrated engineering, purchased from him before and I highly recommend him.
Ok mate nor probs,
ours was mapped we believe to run an atmospheric from the top of my head, this people is why you dont buy already tuned cars with not a lot of history haha,
Can you run an agu bottom end with a aum head, loom, and ecu?
Its just we have a low mileage agu engine we're collecting on saturday.
also i was possibly thinking of reveting back to a standard map the only problem is we're running a full stainless sport cat system, would that make any difference on the standard map?
Cheers again!!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
standard map will be fine with the stainless
Offline shaft69
Ok mate nor probs,
Cheers again!!
Yes can run agu block with aum head done similar on mate audi tt when his block started knocking put agu block with bam head 18 months still no probs.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
