Author Topic: Rust on the wheel hubs anyone  (Read 14393 times)
Offline Discopants9
« on: 13 July 2014, 17:25 »
Anyone having issues with rust on the wheel hubs not sure I have the right terminology here, its painted silver but on all 4 of my wheels its showing about 1/4 of it has now rusted - would this be covered under warranty ?
Offline itavaltalainen
Re: Rust on the wheel hubs anyone
« Reply #1 on: 13 July 2014, 17:33 »
sadly normal... my rear hubs are noticeably rusty....
Offline phazer
« Reply #2 on: 13 July 2014, 17:34 »
Won't be covered on warranty, it's nice that they're painted from the factory actually. They will always rust I'm afraid. Best you can do is take the wheels off rub down and paint with smooth hammerite and it'll last much longer (if you do enough prep a pretty long time :) )
Jackie Treehorn
« Reply #3 on: 13 July 2014, 18:04 »
Hammerite every few years keeps them looking like new. F and E series BMW owners (like me) had it within 1month of ownership. Just get cheap brush and crack on with it  :wink:
« Last Edit: 13 July 2014, 21:08 by Jackie Treehorn »
Offline Talk-torque
« Reply #4 on: 13 July 2014, 20:42 »
This seems to vary, car to car. Not sure why it should, but this is my third Golf and, in this respect, the best of the lot. All 4 still look quite smart, and I live by the sea! As said above, the treatment is to paint them yourself with Hammerite, or something similar. You might also want to do your brake callipers, unless you're lucky enough to have the factory painted jobs.
Roger.
Offline Gnasher
  • Formerly GnasherVXR
« Reply #5 on: 13 July 2014, 22:45 »
I'm out in Cyprus and the car has seen rain (in the time I've had it) less than half a dozen times and the discs are rusting in the centre.
Time for the smoothrite!
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
Offline TheCarMadDad
« Reply #6 on: 13 July 2014, 23:21 »
Isn't the hub part of the brake disc assembly? If so just do a track day and get the discs changed  :evil:
2014 Mk7 Golf GTD 5dr | Tornado Red | Keyless Entry | Climate Comfort Screen > Which means I also have the ATP. Also fitted with DTUK Stage 2 box ...Loving every second behind the wheel!
Previous...
2008 Toyota Prius T Spirit (fastest 0-15mph car I have ever owned :p )
2005 Subaru Legacy 2.5 SW
2003 Lexus IS300
2002 Seat Leon Cupra R
Jackie Treehorn
« Reply #7 on: 14 July 2014, 14:48 »
I have had the hammerite/smoothrite paint bubble on brake hub especially on track days due to the nanny braking system lightly squeezing the brakes constantly. If you do track days you may want to consider the caliper specific paints that are available. But fir road use its been fine otherwise
Offline Bandit127
« Reply #8 on: 14 July 2014, 19:51 »
I have a mk4 with 137k on the clock, so I am not fussy about rusty disk hubs. You can't see much through the flaking on the rims anyway...  :sad:
But if I was I wouldn't use Hammerite. Stove enamel is an old fashioned paint made for high temp applications (i.e. stoves). Much more robust for the application.
Offline scoobyc
« Reply #9 on: 14 July 2014, 20:09 »
Very High Temperature (VHT) engine lacquer will work just as well as any caliper paint kit and cost you a lot less  :wink:
