Author Topic: dump valve help  (Read 2407 times)
Offline bensimm91
Re: dump valve help
« Reply #10 on: 25 June 2014, 09:16 »
Theres a full picture of engine bay in the link now .. i cant find where the pipe should of gone to
Offline MoMartin
Re: dump valve help
« Reply #11 on: 25 June 2014, 13:05 »
That's my recirc valve before it was fitted correctly (The guy had It installed as atmospheric too)
You're missing that pipe that mine is connected to, then the recirc valve goes just behind that round looking thing, that's just above my valve (if you look closely you can see the bung, where it is meant to go. You need to remove that then put the recirc valve in there.)
Offline bensimm91
Re: dump valve help
« Reply #12 on: 25 June 2014, 14:28 »
Thanks for that mate ill have a look at it later so basically my car is losing power due to the air not being taken back in from the turbo
Offline bensimm91
Re: dump valve help
« Reply #13 on: 25 June 2014, 16:37 »
I have just took a look under the hood and its gets worst or better im not sure but the old standard valve is also on it at the place where it belongs so ive got 2 valves wtf
