Author Topic: squeeky front end !  (Read 1383 times)
Offline daddy5x
  • any time now milltek cat back remap
squeeky front end !
« on: 18 June 2014, 10:20 »
morning all  a quick question for you      when i turn my wheeel to the left i get a squeek like im on a newly painted garage floor (tyre sqeek on floor)  but it does it on all surfaces including gravel .its not there allways  but it comes and goes .could this be anything to do with my wheel not bering centered ? thx in advance
standard gti turbo (aum     4 now
Offline Dalo Harkin
Re: squeeky front end !
« Reply #1 on: 18 June 2014, 12:26 »
Power steering fluid level good?
if it is then possibly the rack
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
« Reply #2 on: 18 June 2014, 12:29 »
I had a similar problem it turned out to be my droplink wasnt tight enough, the bottom bolt which goes into the lower arm
Offline daddy5x
« Reply #3 on: 18 June 2014, 12:31 »
cheers fellas ill check both things when im back from work     ,ill let u know
