Author Topic: golf agu running rough  (Read 3486 times)
Offline viperjsy
Re: golf agu running rough
« Reply #11 on: 03 July 2014, 20:13 »
just replaced the maf it seams to be running ok bot it has this code 00561 Mixture Adjustment Control what part could that be
Offline pickles
  • Next!!!
« Reply #12 on: 03 July 2014, 22:07 »
i had this code ages ago, mines was a leak at the air inlet manifold where it meets the block.
you could have a boost/vacuum leak somewhere.
Get a smoke test done.
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline viperjsy
« Reply #13 on: 04 July 2014, 03:36 »
dont think jersey has a one
Offline viperjsy
« Reply #14 on: 04 July 2014, 21:15 »
when I replaced the maf I seem to be boosting a bit more it has gone up from 0.4to 0,6 bar
Offline viperjsy
« Reply #15 on: 07 July 2014, 18:01 »
think I have found the vac leak I did not tighten some clamps on the oil catch can where the t peace is
