Author Topic: s2000 filter  (Read 1708 times)
Offline Jarrold06
s2000 filter
« on: 07 June 2014, 21:36 »
Ive seen on here that people are putting s2000 filters on there golfs do they just slip on or need any modification going on at all and another thing does it make a difference at all thanks
Offline brett
Re: s2000 filter
« Reply #1 on: 07 June 2014, 21:39 »
If you do a search there's loads of posts covering this ,but I believe you have to buy a reducer for the filter to the maf
Offline Jarrold06
Re: s2000 filter
« Reply #2 on: 07 June 2014, 21:54 »
Oh right ok mate nice one
Offline northeast_gti-t
  • "1.8T AGU"
Re: s2000 filter
« Reply #3 on: 08 June 2014, 00:05 »
You will need a reducer the standard maf diameter is 70mm and the filter diameter is 80mm i got a 76-81mm for mine went over the maf and tightened up fine even with a 1mm clearance it was a pain to get the reducer on the filter end   :grin: Dom managed to fit an 80mm diameter reducer on  :laugh:
http://www.jsperformance.co.uk/silicone-hoses/straight-reducing-silicone-hoses/coolant-air/81-76mm-straight-reducer-hose.html
http://www.eurocarparts.com/air-filter
2000 Mkiv GTi 1.8T AGU
Offline Jarrold06
Re: s2000 filter
« Reply #4 on: 08 June 2014, 00:50 »
That's not a bad price although I haven't got a standard air filter on mine though I brought the car and it's got a piper x one on it if I'm honest I think I might just need the filter but I'm not going to be cheap on this If I do it then I will be doing it properly just thought I'd ask going to wait though till I got some dolla does it bring anymore power or stay the same
Offline benmanc
Re: s2000 filter
« Reply #5 on: 08 June 2014, 21:52 »
Looks a little long thay reducer. Not much room to play with when you got a short one.
I have a brand new one if you want to buy it as I bought 2. Its 80mm.
Needs a little persuation and lube/washing up liquid to get on but its doable.
Offline Jarrold06
Re: s2000 filter
« Reply #6 on: 08 June 2014, 22:04 »
If i decide to get one i will get it off u mate thanks for the offer
