Author Topic: Boot Opening  (Read 12429 times)
Offline martinc1967
Re: Boot Opening
« Reply #20 on: 02 June 2014, 22:52 »
I just wouldn't see the point in having a button on the remote if you needed to use the badge to open it anyway??
Why!!! Lol!
If that were the case and you did the mod, the boot lid still wouldn't open even with the stronger struts?
Maybe yours and mine have faulty latches?
Any thoughts chaps?
Regards,
Martin
Offline martinc1967
Re: Boot Opening
« Reply #21 on: 03 June 2014, 12:56 »
Hi Chaps,
As you may know I have just purchased my Mk6 GTI.
I have noticed on the remote there is a button to open the boot. But when you press it, it does unlock but doesn't open up?
Should it open up? I suspect not? Which seems a little odd as you still have to use the handle to raise it?
However, if you replaced the neumatic arms (if that's right??) with stronger ones, would it open once you press the button?
Has this been covered before/anyone done it?
Regards,
Martin
The boot button on your key fob unlocks the boot only (for a few seconds). It will re-lock the boot after a few seconds of non-activity and/or lock the boot once you have opened and closed again.
I don't tend to use this button though as if the key is accidentally left in the boot then could be in a situation !
Red
Correct to an extent i doesn't just unlock it pops theres a solenoid in the lock that pushes the boot off the stop
Ah Haaaa!... Looking at the pdf instructions, apparently the Golfs of a certain year require some diagnostic coding too once this mod has been done, as when you release the boot with the remote, it goes onto a secondary latch!!! Diagnostic coding stops the secondary latch!
Also, I heard that after the mod, the hatch can some times stick out slightly (alering the shut line). This can also be rectified by re adjusting the boot latch a couple of mm!
Great!
Regards,
Martin
« Last Edit: 03 June 2014, 13:11 by martinc1967 »
Offline Booth11
Re: Boot Opening
« Reply #22 on: 03 June 2014, 14:14 »
Great!
Regards,
Martin
That explains why you need to release using the badge then.  At least it's not broken.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline jonathan_phang
Re: Boot Opening
« Reply #23 on: 14 June 2014, 19:13 »
Mine also doesn't pop once the boot button is held. Do you have further info about the coding needed to disable the secondary mechanism? What PDF do you mean?
Was looking to get the ecs kit but didn't bother as I thought my latch was faulty. When I put her in for a service a couple of months back in asked VW and they said that was meant to be the way it works. I couldn't be bothered to argue with them that people had it popping.
Any info appreciated
Jonny
Candy White MK6 Golf GTD | DSG | Heated Leather | RNS 510
Offline martinc1967
Re: Boot Opening
« Reply #24 on: 14 June 2014, 22:31 »
Hi jonny,
I've found lots of conflicting info about this. Apparently, different year models have diff boot locks. Some have the secondary locks, some don't. And you can't change the programming. I can't find a definitive answer and I'm not sure what's right or wrong? I can't believe there would be different lock settings??
Until it's clear, I can't do the mod!
Frustrating!
Regards,
Mart
Offline Obbzi
Re: Boot Opening
« Reply #25 on: 16 June 2014, 00:14 »
I have done the boot open mod and it's ace :cool: comes in handy especially with 2 kids and Hands full of shopping! :smiley:
2008 R32 DBP gone. 2008 GT TDI going 2009 GTI coming soon!
Offline Stevie35
Re: Boot Opening
« Reply #26 on: 16 June 2014, 00:39 »
I found this a very strange one too, why give u the button if the boot isn't going to open fully. Now I looked into the boot pop mod and then purchased the parts required via a group buy on another forum. So as standard when I pressed and held the button the boot pops of the catch but through its own weigh kind of latches back on so you still have to use the badge to open it. I then fitted Leon ball pins, fabia struts and scirocco bumpers(which I believe is a cheaper alternative to the ecs tuning kit) then press and hold the button and hey presto the boot pops open an inch which only required lifting slightly to open fully from the boot edge not the badge. It didn't pop all the way open as some have. Then I tried to close the boot having stronger struts makes this slightly more difficult so that isn't great. I decided to live with it and see how it went.
After 2 days of having the new gear fitted the tailgate started to rattle and squeak like mad, nothing I did could help it. So I decided to remove it. Whilst doing this I decided to try one thing so I fitted the original ball pins and struts but kept the scirocco bumpers and hey presto it achieved the same result pops the boot open an inch so effectively it lifts it clear of the latch so u can just lift with one finger and tailgate lifts up. However having the longer scirocco bomber fitted I noticed the boot didn't quite fit flush the tail lights didn't seem to line up properly and this was following the guide from ECS Tuning on YouTube.
So now I have 2 fabia struts, 2 Leon ball pins and 2 scirocco bumper lying in my garage, and when I need to open my boot I just do it as VW intended when they designed the clever system of making the boot badge the boot release. So far it's working out well and the tailgates is back to being rattle free.
My advise would be to forget about the stupid button that looks like it will open the boot and just use it normal, don't buy a boot pop kit there just pants.
Edition 35 3dr, Steel Grey, Manual, Sat Nav
Offline martinc1967
Re: Boot Opening
« Reply #27 on: 16 June 2014, 13:11 »
Hi Obbzi, What year is your GTI? No secondary latch or protruding boot lid after fitting?
Steve... very frustrating!!! Is yours a Mk7? if not, what year pls?
Regards,
Mart
VERY FRUSTRATING! :laugh:
Offline Obbzi
Re: Boot Opening
« Reply #28 on: 16 June 2014, 16:15 »
Regards,
Mart
Mines a 59 plate Mk6
Offline martinc1967
Re: Boot Opening
« Reply #29 on: 16 June 2014, 17:28 »
Regards,
Mart
Mine too! but when I press the remote boot release, it goes on to a secondary latch (so you need to open it with the badge). How did you get around that problem so it just opens up?
Regards,
Mart
