Author Topic: Sparks at start-up.. immediately dies.. HELP :(  (Read 12702 times)
Offline xAntiVenxm
Re: Sparks at start-up.. immediately dies.. HELP :(
« Reply #40 on: 14 June 2014, 17:21 »
Right I can find no wiring cracked or broken at all!! All vacuum hoses look absolutely fine..
Isv has been totally bathed in carb cleaner and all the sensors I could get to had the contacts cleaned with contact clean.
Wondering if it's the little switch on the throttle body where the accelerator cable connects.. when the cable is slacked the plastic it clamps to clicks the switch.. which I believe sends a signal for the engine to idle..
So I am guessing it's either the isv or that switch not working. If cleaning doesn't sort it will try replacements for those..
Although other suggestions welcome!!!
Offline Screech16v
  • MK3 20vt AGU
« Reply #41 on: 14 June 2014, 20:17 »
Take the isv off and put 12v to one pin and earth to the other pin,look into it as you switch it on and off repeatedly,it should click and you should see movement inside,if it's stuck stick a thin screwdriver up it and push the valve
Offline xAntiVenxm
« Reply #42 on: 14 June 2014, 22:20 »
HERO!!! IT WORKED!! SHE LIVES!!!!!! :D
Offline sharki786
  • GOT BOOST??
« Reply #43 on: 14 June 2014, 22:21 »
YAYYYYY!!! lol
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline xAntiVenxm
« Reply #44 on: 14 June 2014, 22:25 »
YAYYYYY!!! lol
Hahaha XD
Dunno what happened I posted a long reply but it disappeared lol ah well
Offline Screech16v
  • MK3 20vt AGU
« Reply #45 on: 15 June 2014, 22:35 »
Good news!
Offline xAntiVenxm
« Reply #46 on: 15 June 2014, 22:45 »
Good news!
thanks for idea mate  :grin:
started her again still running! Still needs a good whack on the idle valve to free it so it doesnt run rough though..
reckon some wd40 in there would help?? trying to not have to replace it.. it's obviously a bit stuck in there, needs lubricating it seems or could just need to be replaced?
Offline Screech16v
  • MK3 20vt AGU
« Reply #47 on: 16 June 2014, 19:36 »
Soak it in penertrating fluid and keep working it,should come good,they are quite pricey to buy new
Offline xAntiVenxm
« Reply #48 on: 22 June 2014, 00:54 »
did just that :) WD40 bath and its perfect.
running is still a bit odd. cant put my finger on it, just sort of rumbles every now and then.. but it may just be the engine, i'm too used to my ford tbh.
cam belt probably needs changing and timing checked, seeing as she sat still for so long i wouldn't be surprised if the belt has started to go stiff, and is stretched in the position it sat in for years.
finally got underneath her properly..
lotta sill rust.. :( doesn't look very crumbly though, so i don't think should be more than an advisory on MOT.
drivers side CV boot is split and needs changing..
both ball joints are rotted.
also it looks like some monkey attacked the locking wheel nuts with a windy gun  :angry: spent today chiseling the collars off em and smashing a socket onto em.
3 down one to go..
all the wheel nuts are ruined, either corroded as hell or they were crossthreaded at some point - but the absolute novice who had it before me had those terrible halfrauds £10 wheel spacers on em behind the wheels.
was lucky not to snap a bolt, with how short they were inside the hub!!
must've been typical chavvy kid, thinking of the looks but not thinking of getting extra long wheel nuts for safety!
straight in the bin  :drool:
and now sleep.. arms ache  :laugh:
