Author Topic: how do i get the display lcds like this (pic inside)  (Read 5722 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: how do i get the display lcds like this (pic inside)
« Reply #10 on: 31 May 2014, 15:30 »
You should be good with just the film mate.
Offline sharki786
  • GOT BOOST??
« Reply #11 on: 31 May 2014, 16:45 »
100%?? I have the anni type clocks. Not the old clocks bud.
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #12 on: 31 May 2014, 17:37 »
The LCDs are a bit trickier to remove from the housing on late clocks and i can't remember if you can separate the oe film without desoldering them or if you can just pull them out carefully unlike the early ones as demonstrated here : http://www.dubdesignindustries.com/installation/golf-lcd.pdf
Offline sharki786
  • GOT BOOST??
« Reply #13 on: 31 May 2014, 18:09 »
Ive just taken the polarising film off, was abit hard to take off. I made a mistake of heating it up with misses hair dryer. By heating it up you will leave some glue on the lcd. I have cleaned both lcds up with white spirit. I remeber when i was young i used to take my calculator apart and flip the film over. I might go poind shop and buy a big cheap a$$ calculator and see if that works. By flipping the film around the lcd goes dark and number are colourless.
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #14 on: 31 May 2014, 23:54 »
I have ordered the film from awesome and some red smds as i thinm they have been changed to blue smds.
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #15 on: 04 June 2014, 19:14 »
People i need help with splitti g the circuit board from the back white casing. I cant find a diy for the later clocks. Any help?
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #16 on: 12 June 2014, 23:44 »
Theres a problem. I have taken the old polarised film off the lcd and put the new one on but they look same as before. The screen is not dark if i put the glue side onto the lcd but if i rotate it the lcd becomes dark. Have they sent me the wrong kit? Also the instalation guide is about fitting plasma dials.
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #17 on: 13 June 2014, 13:50 »
Well i spoke with awesome and they said that the adhesive must be on the wrong side. So i need to send them back and they will sent me another set that they have on the shelf. Its funny how the adhesive is on the wrong side.
*****MK4 GTI T*****
« Reply #18 on: 13 June 2014, 14:01 »
How irritating,  glad to hear you've cracked it though mate.
Offline sharki786
  • GOT BOOST??
« Reply #19 on: 13 June 2014, 15:42 »
i know oh well never mind. I wasnt so sure if i was doing it right. But what i did was take the film off the lcd (so now the lcds will be blank) and then put the film on the way it ment to, but when i took the film off to stick it to the lcd it kept falling off only to realise that the glue is on the wrong side lol
*****MK4 GTI T*****
