Author Topic: Engine management light on  (Read 3570 times)
Offline itavaltalainen
Re: Engine management light on
« Reply #10 on: 25 May 2014, 22:20 »
they should be able to check if there's a TPI if you tell them your VIN
Offline mike.
« Reply #11 on: 26 May 2014, 09:34 »
The coil pack part number is 06H 905 115 B this was the new version introduced in 2012.
They should be about £30 each from what I remember.
I had the same problem on a 2010 car and just replaced all four in anticipation of the others failing.
If you go the R8 coil pack route I think you need to change the plugs as well according to some of the other forums.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline bcarlin
« Reply #12 on: 26 May 2014, 22:29 »
Replaced coil pack today and all is well  :smiley: thanks for all the help
