Author Topic: possible fuel leak!  (Read 3040 times)
Offline daddy5x
  • any time now milltek cat back remap
possible fuel leak!
« on: 18 May 2014, 20:43 »
after having a bit of a clean under the bonnet  I noticed  a wet patch around all 4 fuel injectors .is this normal?  or do I have to replace any thing like gaskets  seals etc   thanks
standard gti turbo (aum     4 now
Re: possible fuel leak!
« Reply #1 on: 18 May 2014, 21:25 »
Injector seals as a guess but I would not use it until they are fixed.
Offline daddy5x
« Reply #2 on: 18 May 2014, 21:36 »
is it dangerous  :cry:
« Reply #3 on: 18 May 2014, 21:39 »
If it is 100% fuel then yes it is dangerous as it is under high pressure.
Offline daddy5x
« Reply #4 on: 18 May 2014, 21:43 »
ill get new seals tomoz then        thx wayne
Offline Nino
« Reply #5 on: 18 May 2014, 22:00 »
Iy will be the injector seats not the seals however the seals are known to fail also and dont cost alot to replace
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline davidgtrr34
« Reply #6 on: 18 May 2014, 23:33 »
If it is the injectors you should have a vucuum leak. Can you hear any hissing around the injectors.
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline dom
  • Back in a Mk4
« Reply #7 on: 19 May 2014, 13:12 »
Almost certainly the seats, I'd replace them as soon as you can but it should be fine to drive in the meantime. Chances are they've been leaking for ages already.
Offline Nino
« Reply #8 on: 19 May 2014, 13:25 »
I have a set of brand new seats the upgraded version never used pm me if you want them £25 posted
Offline WadGTI
  • Golf GTI'er
« Reply #9 on: 19 May 2014, 13:37 »
remember 21mm hex to get the seats out or similar shaped object
