Author Topic: Rocker cover gasket replacement  (Read 3177 times)
Offline james2
  • No scammers please.
Re: Rocker cover gasket replacement
« Reply #10 on: 17 May 2014, 18:26 »
Cool, how long did it take you? Do I need a torque wrench ?
I need to do mine, because it is leaking out the back and into number 4 spark plug hole. Do not worry about a torque wrench. Only bolts i torque up are wheel bolts and cylinder head bolts.  :smug:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Scottymk4
« Reply #11 on: 17 May 2014, 19:57 »
Cheers james
Offline viperjsy
« Reply #12 on: 17 May 2014, 20:58 »
About 30 mins 7 nm torq
« Last Edit: 17 May 2014, 20:59 by viperjsy »
Offline Scottymk4
« Reply #13 on: 17 May 2014, 21:01 »
Thanks guys... Will give it a go when the rain stops  :cry:
Offline brianpologti
« Reply #14 on: 17 May 2014, 21:03 »
it comes in the kit m8 just did mine
[/quote
Ecp one comes in two parts inner and outer WTF, why would u change one bit?
Offline viperjsy
« Reply #15 on: 17 May 2014, 21:05 »
No problem
Offline dom
  • Back in a Mk4
« Reply #16 on: 17 May 2014, 22:53 »
Rain??!
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #17 on: 17 May 2014, 22:55 »
Gasket set will come in two parts usually
2000 Mkiv GTi 1.8T AGU
Offline Scottymk4
« Reply #18 on: 17 May 2014, 23:42 »
Yeah Dom... Rain it is Scotland after all  :laugh:
