Author Topic: Spark plug change  (Read 2572 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Spark plug change
« Reply #10 on: 17 May 2014, 22:50 »
It was easy but not happy as there was some oil on 3 out of 4 plugs
You will need to replace the rocker cover gasket.
As barry says mate real easy to do
mainly the centre gasket as these leak and you will have the symptoms you describe just fit both new ones as you'll have to remove the cam cover anyway
2000 Mkiv GTi 1.8T AGU
Offline Scottymk4
« Reply #11 on: 17 May 2014, 23:43 »
Yeah it was easy to change the plugs not looking forward to the gaskets though
  • "1.8T AGU"
« Reply #12 on: 18 May 2014, 01:01 »
Doddle mate its really quite easy if you can change the plugs you can change the gaskets  :grin:
