Author Topic: Fuel pump or something else....  (Read 2934 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fuel pump or something else....
« Reply #10 on: 16 May 2014, 18:12 »
your cat won't last long if your pre cat lambda is dead...
Offline Rhyso
« Reply #11 on: 16 May 2014, 22:46 »
Engine speed sensor is the crank sensor if im right. They can deteriorate because of the heat from the engine.
That's the one mate, its to the side of the oil filter on the block,. Its all fitted now so I'll have to see how I get on  :smiley:
Sounds like you've found the cause. Classic symptoms if once warm the car refuses to restart until the sensor has cooled down
