Author Topic: Rear Boot screen Trims.  (Read 9080 times)
Offline peterdoherty
Re: Rear Boot screen Trims.
« Reply #20 on: 30 May 2014, 19:01 »
Thanks for that. I don't have IPA/panel wipe I'm afraid. Do you think it'll be ok to apply after a good wash and dry or is it worth getting some?
Yes should be grand as long as its clean and dry
MKVII GTD DSG Carbon Grey 5DR, Dynaudio, Keyless Entry, Rear View Camera, Colour MFD, Park Assist, Winter Pack, Climate Screen, Advanced Phone Kit, High Beam Assist
Offline iandjm
« Reply #21 on: 30 May 2014, 19:04 »
I had one of the trims replaced at the dealer today.  Looks a good job.  :cool:
2017 MY Golf R 3dr DSG | Lapiz Blue | Dynaudio | Heated Screen | Advanced Phone | Sat Nav | Winter Pack
Offline p3asa
« Reply #22 on: 30 May 2014, 23:31 »
Once clean I'd sit the trim on the glass and line it up.
Once lined up run some masking tape or any tape down the glass parallel to the trim so when you are fitting it for real you know exactly where its going.
You'll only get one chance to get it right.
Offline iandjm
« Reply #23 on: 21 June 2014, 15:05 »
Well after 2 weeks the new trim is now coming unstuck!  It appears to be the glue between the trim and sticky pad that fails (I assume the trim is supplied like this). Here we go again  :embarrassed:
Jackie Treehorn
« Reply #24 on: 21 June 2014, 15:28 »
Has anyone tried using a little Tiger Seal?
Sure that would work and not come away from the glass.  I understand its something that the dealer could/should do, but it may be more likely to get done properly by yourself with Tigerseal.
