Author Topic: Questions/checks when collecting your GTI/D....  (Read 18003 times)
Offline valvebounce
Re: Questions/checks when collecting your GTI/D....
« Reply #20 on: 13 May 2014, 22:42 »
Engine braking forces the piston rings against the bores.
When the throttle is open the combustion gases push against the inside diameter of the piston ring, forcing it to expand radially onto the liner bore. On the overrun (engine braking) when the fuel is cut there is no combustion so the radial load is much lower, there is only the static ring tension plus the gas load due to pumping.
Offline Trialsash
« Reply #21 on: 13 May 2014, 23:40 »
Is there a bottle opener in the mk7 then?? I don't seem to have one, photo somebody please :-) thanks
Offline valvebounce
« Reply #22 on: 14 May 2014, 06:32 »
No, sadly not. The list was copied from the mk5/6 forum. The bottle opener was a lovely touch, as was the exclusive owners manual folder with gti badge and red stripe. VW are much more focused on profit now. Shame.
Offline marnie
« Reply #23 on: 15 May 2014, 21:08 »
Does anyone know if it's possible to feel for any transport blocks by squeezing the shock absorber gaiters with the car on the ground please?
Mk7 GTI 5 Dr
Offline TheCarMadDad
« Reply #24 on: 16 May 2014, 00:01 »
I'm also interested in this marnie. Seen a lot on here about the pucks but how can you check if they've been left in? Is it just a case of looking under the arches?
2014 Mk7 Golf GTD 5dr | Tornado Red | Keyless Entry | Climate Comfort Screen > Which means I also have the ATP. Also fitted with DTUK Stage 2 box ...Loving every second behind the wheel!
Previous...
2008 Toyota Prius T Spirit (fastest 0-15mph car I have ever owned :p )
2005 Subaru Legacy 2.5 SW
2003 Lexus IS300
2002 Seat Leon Cupra R
Offline monkeyhanger
« Reply #25 on: 16 May 2014, 07:36 »
You'll have to jack up the front wheels 1 at a time so that the wheel is hanging low on the suspension and there's a decent gap between the wheel top and the wheel arch. Then feel around the rubber gaiters of the shock. The bump stops are conical and don't move from the top of the suspension mount, the pucks (if there are any) are cylindrical (around an inch thick) and can slide up and down the suspension strut.
Offline GerryD
« Reply #26 on: 31 August 2014, 12:37 »
Sorry to drag this thread up again, but as I am sure there are going to be people picking up new cars in the next week I didn't want to start a new one.
I am picking mine up on Wednesday, and just wanted to clarify what cables to expect with the Nav Pro?
I have read about getting two, a lightning one and a USB. Is this right?
The car is also keyless, do you get the GTD key fobs, or anything similar?
Are there any other little touches or things that are not in the brochures?
Thanks in advance.
Tornado Red Mark 6 GTI
Carbon Steel Grey Mark 7 GTD
Previous: Mark 3 TDI GL
              Mark 4 GT TDI
              Mark 5 GT TDI
Offline Jimble
  • Moderator
« Reply #27 on: 31 August 2014, 13:40 »
You don't get any cables with the pro nav, it has a usb socket in the cubby so you can connect any devices with their own cables.
Although i did get two mdi cables with mine but nowhere to stick em?? ??? ;D
Offline KyleB
« Reply #28 on: 31 August 2014, 14:31 »
You should still get the fobs even with keyless. This is one of the most missed things by dealers I think.
Stick em on eBay!  :tongue:
Offline GerryD
« Reply #29 on: 31 August 2014, 15:12 »
Thanks for the replies.
Never knew about the cables.
Got my music SD card sorted, and it plays in An Rns510, so hopefully no problems in the new car.
Will check the keys also..
Anything else?
              Mark 4 GT TDI
              Mark 5 GT TDI
