Author Topic: Turbo or boost fault?  (Read 3590 times)
Offline harlemex
Re: Turbo or boost fault?
« Reply #10 on: 23 June 2014, 23:00 »
mine did this and it was my maf.
Offline MoMartin
« Reply #11 on: 24 June 2014, 11:24 »
This
Edit - well the fault code was maf the boost spikes were throttle body i believe (as nino suggested)
« Last Edit: 24 June 2014, 12:22 by MoMartin »
Offline Dalo Harkin
« Reply #12 on: 24 June 2014, 12:16 »
may also be worth cleaning the throttle body in case its sticking
Offline Tezmax
« Reply #13 on: 25 June 2014, 10:29 »
Maf changed but made no difference. Will clean throttle body this afternoon and see how it goes. Got no vagcom to realign though. Whats the symptoms if TB adjustment required?
Thanks.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline daddy5x
  • any time now milltek cat back remap
« Reply #14 on: 26 June 2014, 22:09 »
should realighn its self after a few miles
standard gti turbo (aum     4 now
Offline dom
  • Back in a Mk4
« Reply #15 on: 27 June 2014, 17:45 »
No it won't. His is an AUM which needs realigning with VAGCOM.
