Author Topic: GTD acceleration responsiveness  (Read 49108 times)
Offline adekil
Re: GTD acceleration responsiveness
« Reply #30 on: 12 May 2014, 12:06 »
I used Normal a lot over the last months and just recently and each time I start up the car in Normal (after leaving it in Normal) the responsiveness is just Normal, certainly not as lively as Sport (once the switching out and in is done)
There were times when I was driving in Sport (started in Sport) and when switching to Normal the car felt livelier - So for me starting in any Mode I don't seem to get the best out of that particular Mode without switching.... Although I only really use Sport, Normal & Individual (set to Sport in most)
With that said and Normal mode seemingly more responsive at times I'm still not convinced the engine is defaulting to Normal. So regardless of the car being warm or cold how can Normal mode give at least 2 different feels in responsiveness. I remember reading some reviews that the GTD Normal mode was just as good as Sport if not just slightly behind it, but in my opinion its quite far behind Sport until you perform the Mode switch.
Current(2024): MK8 Golf R, Pure White, RV Camera & 19" Estoril Diamond Cut
Offline Gordor
« Reply #31 on: 12 May 2014, 22:01 »
After reading this thread I thought I'd give it a go. Mine is set on individual, most on sports and there is a definite improvement when I switch the car into eco mode and then back again.
GTD Pure White : 19" Santiago's : Winter Pack : Dynaudio : Park Assist : High Beam Assist
Offline KyleB
« Reply #32 on: 14 May 2014, 16:24 »
I was intrigued reading this thread and tested this out for myself last night. Couldn't see a big improvement, but I'm going to keep investigating. Like Gordor my car is always in individual (everything sport apart from ECO air-con)
Anyone got any further findings?
Offline adekil
« Reply #33 on: 14 May 2014, 17:07 »
KyleB, when did you receive your car? Mine was delivered 1st October, so perhaps this bug is isolated depending on when the car was built
Offline monkeyhanger
« Reply #34 on: 14 May 2014, 17:21 »
The mode issue some of us are having doesn't seem to be restricted to build week. Adekil seems to have gotten his within a week of mcmaddy, who doesn't have the issues. I got mine 8th Sept, a BW33 car.
Any common denominator like lack of options etc? I have no options on mine. Just wondered whether there is a default ECU flash that gets modified when options are added, maybe the default/unmodified flash is buggy?
Offline adekil
« Reply #35 on: 14 May 2014, 17:44 »
I can't see anything common here with options or anything else then if not build week.
Checked other forums too and nothing comes up.
Tomorrow will book the car in with VW and hopefully get a soonish slot and feedback anything or nothing!
Offline mcmaddy
« Reply #36 on: 15 May 2014, 08:15 »
Kyle with yours in eco air con does your windscreen not fog up?
Offline adekil
« Reply #37 on: 15 May 2014, 10:45 »
Car is booked in now to check this mode change, the lease company guy understood exactly the explanation of the bug, just a question if VW get it.
Offline KyleB
« Reply #38 on: 15 May 2014, 18:33 »
No fogging at all unless I put the air recirculation option on.
My car was delivered 19th September. Options are 19s, Nav and Metallic Paint.
Offline adekil
« Reply #39 on: 15 May 2014, 20:29 »
My car is booked in with VW on the 29th May specifically for this mode/performance issue... watch this space!
