Author Topic: Air filters and set ups!  (Read 1463 times)
Offline Dalo Harkin
« on: 30 April 2014, 12:53 »
As this topic keeps coming up, regardless how many topics there are on it, does anyone actually have any facts about what is 'the best' now I know it will depend on stages etc.
Take me for example, I have tried nearly every type going, and I do prefer the quiet stock box with a pipercross filter or something inside but it really seemed to struggle for air.... I would still like to go back to this if I can as it seems the 'best' option for me as I want it quiet when needed but then when I open it up I want to hear it
Someone with some stats in terms of what they can handle etc would be good...
Offline dom
  • Back in a Mk4
Re: Air filters and set ups!
« Reply #1 on: 30 April 2014, 13:05 »
Really? Do we need another?
Offline Dalo Harkin
« Reply #2 on: 30 April 2014, 17:35 »
All the others tend to be what do you have.... I want to know what can it cope with.....
I want facts as opposed to opinions really  :wink:
Offline paultownsend
« Reply #3 on: 30 April 2014, 18:00 »
Right. I have wasted a lot of money on this too.
So I have the stock set up. Silicone forge TIP. PiperX foam filter. 710N DV. However where the OE snorkel meets the box, I have opened it up an inch or so either side.
So it gets all the cold air from the OE intake, yet can suck up as much sure as it can swallow.
I have also taken the plastic mesh out where the normal intake starts from under the bonnet.
No silly induction roar. Just a nice subtle DV sound
Offline dom
  • Back in a Mk4
« Reply #4 on: 30 April 2014, 18:36 »
Hmmm, I've currently got a pipercross filter and the OE airbox along with venair TIP and Forge 007p. I've ran a larger cold air feed from the front bumper vent which I've drilled and am going to open up the bottom of the airbox some more.
The induction noise from the S2k filter was annoying me a bit and I'm enjoying the quiet of the OE box.
« Reply #5 on: 30 April 2014, 18:55 »
Best set up IMO. I thought the s2k was awful. Sounded like the fast and the furious and felt like it lost a lot of low down drivability
Offline Scott D
« Reply #6 on: 01 May 2014, 00:04 »
I can't fault the S2000 filter it works well the rest of hardware and seems to pull harder top end although did fit a SFS supersize TIP at the same time.
I like the induction roar too  :grin:
Think there was a thread on Audi Sport comparing airbox vs Jetex vs S2000.
I'd do some logging but don't have a working VCDS lead nor a standard airbox
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline dom
  • Back in a Mk4
« Reply #7 on: 01 May 2014, 07:23 »
I can do some logs with mine to see, but it'll have to wait until I've got some spare time.
